Everytime I try to Convert a Specific .Bin (Movie Files, .r00, r01, etc) to VCD or SVCD using ffmpegx, I keep getting the same errors.
Here is the error I get when I try to convert a .Bin to VCD:
VCD - mpeg1 (ffmpeg)
Encoding started on Thu Dec 2 15:13:11 AST 2004
usage: movtoy4m -w width -h height -F a:b -a a:b [-s] [-f] [-o ppm/y4m] movie.mov
example: movtoy4m -w 352 -h 288 -F 25:1 -a 4:3 pal_normal.mov
example: movtoy4m -w 352 -h 240 -F 30000:1001 -a 16:9 ntsc_wide.mov
pipe:: Error while opening file
And the other is:
VCD - mpeg1 (mpeg2enc)
Encoding started on Thu Dec 2 15:15:21 AST 2004
INFO: [yuvscaler] yuvscaler (version 1.7.0) is a general scaling utility for yuv frames
INFO: [yuvscaler] (C) 2001-2002 Xavier Biquard <xbiquard@free.fr>
INFO: [yuvscaler] yuvscaler -h for help, or man yuvscaler
**ERROR: [yuvscaler] Could'nt read YUV4MPEG header!
**ERROR: [mpeg2enc] Could not read YUV4MPEG2 header: system error (failed read/write)!
Can anyone help me out?
From what you are saying you reassembled a spilt rar file and now have a bin/cue to deal with.
Bin/cue files are usually ready to burn vcd or svcd images. So if you think this is a vcd and you just want to end up with a vcd disk do this:
Go to the copy section of Toast, select bin/cue option, drop the cue file on toast and burn,
Otherwise, if you want to get your hands on the movie file itself, then do as above, but instead of hitting burn, save as disk image from the toast file menu, then mount the image and copy out the mpeg file.
Hope this helps. -
Use GNU VCDTools X to rip the mpeg out onto the desktop. VCDGear X will also work. Then just drag the mpeg onto the video tab of toast.
Hmmm, the thing with that is that the .Bin/Cue file is like 800-900 Megs. Is there a way I can Splite it on 2 Discs? Or will Toast Automatically splite everything up?Originally Posted by alph
bin files can be 800 to 900 megs and still fit on a CDR. The max I had was a VCD Bin that was 923 megs. Toast Had No Problem.
Q"Good Luck 007"
In Memory of Desmond Llewelyn -
qshartle is probably right in that the bin/cue files were made to fit on a CD to begin with. If toast fails with not enough space available on disk: do what I said above to get the mpeg, or use the other tools suggested by pixeljammedia, and you can then split and re-author each part with ffmpegx as 2 separate sets of bin/cue which you can then burn.
Regards
Installed ffmpegX but not converting
By bene07 in forum ffmpegX general discussionReplies: 2Last Post: 2nd Dec 2010, 15:42 -
Converting RM using ffmpegX
By cmc2008 in forum ffmpegX general discussionReplies: 43Last Post: 30th Nov 2009, 02:09 -
installing ffmpegx' binaries | ##/bin/sh: line 1: 5146 Illegal instruction
By veranyon in forum ffmpegX general discussionReplies: 1Last Post: 29th Oct 2008, 13:13 -
Ffmpegx freezes when converting rm
By neilaja in forum ffmpegX general discussionReplies: 3Last Post: 1st Dec 2007, 22:52 -
ffmpegX crash when converting to DVD
By granoli in forum ffmpegX general discussionReplies: 0Last Post: 2nd Jul 2007, 18:39
