Page 2 of 2
FirstFirst 1 2
Results 31 to 32 of 32
  1. I use photoshop. I made template for full cover print cd/dvd and hub ring printables.
    Goto www.customcdlabels.com I donate there regularly and alot of other good stuff for console, movies etc..
  2. Originally Posted by lordsmurf
    Using PS6 here.
    Yeah, I knew about the eliptical tool, it was exact sizing I did not know. But I have to right click and go to a menu, which bring up exact sizing to input numbers. I did not know that was possible, dug around where you said set numbers.
    I usually do guiders by eyesight or exact measure. The new guides from the dropdown menu is in cm/in/etc, not % ... but manually typing in 50% worked too. Other new trick.
    What I was saying is that 22mm seems awfully small, too small, for the hole. Are you sure that's the hub hole measure?
    PS6 ? sorry to hear that
    It's much easier in 7 and CS as you can see
    Yep 22mm. the actual hole (bore) is 15mm. One reason why I like them so much
    BTW here is the regedit to set the bore to 15mm
    Windows Registry Editor Version 5.00
    [HKEY_USERS\S-1-5-21-1409082233-1060284298-1417001333-500\Software\CORPUS\EPSON Print CD\Printings]
    "Bore"=dword:0000000f
    Edit: well hell, I just saw that feather setting and decided to try it
    I like it....Way cool and it will save me time in the future
    Originally Posted by jagabo
