I'm getting a printer which can print on DVDs - probably the R200. I have the impression that the included software is not very good for creating my own labels/images (what's the right term to use here?). What software would be better?
Results 1 to 30 of 32
For making your images. Adobe Photoshop would be the best i think, or Paint shop.
I'm not sure if I explained what I want properly. I'm not actually going to create my own artwork. I'll be combining an existing image or two with text. I know I could do that in Photoshop but setting up a template to use with a DVD seems rather complicated unless I can find one premade.
OK i got you..ok search the forum. afew days ago someone posted a template of a CD, I'll try to find it for you..
What's hard about it?Originally Posted by Michelle
File ->NEW
300dpi, white background,
then take out a ruler and measure your case to input case dimensions.
Template?
FAQs: Best Blank Discs Best TBCs Best VCRs for capture Restore VHS -
Ohhhhh....... in THAT case....
I would suggest changing the title to
"what software to make disc art for R200"
... and those R200 owners will surely help you out.
I would still use photoshop for the art, but you'll need something else for the layout and printing of it. Maybe the R200 comes with something?Want my help? Ask here! (not via PM!)
go into PS and create a new file 120mm x 120mm
600dpi / transperant background
select the eliptical marquee tool
select fixed size 118mm x 118mm
click on the background. then use the arrow keys to center it
goto "select" and click on inverse
use paint bucket to fill in outside area
do the same thing for the middle hole at 22mm (print to hub), but do not select inverse
save file as template
done
PS, change mm to match your CD/DVD's actual size -
I use the SureThing CD labeling package and it will print directly to a DVD on my R200. It will also import images from photoshop or any other imaging program.
I use photoshop to create the artwork.
Then I import the file in Print CD (Epson R200 bundled s/w).
Easy.
The Print CD s/w can also do a couple of simple things like text placement, rotation, color gradation, etc. -
I cannot seem to get the hub hole lined up 100%, but this works.Originally Posted by stiltman
I didn't know you could instruct actual size on the eliptical tool. Very nice.
Right-click, save as:
http://www.digitalfaq.com/photoshop/disc-art-template.gif
You're on your own for hub holes.Want my help? Ask here! (not via PM!)
new guide vertical 50%Originally Posted by lordsmurf
new guide horizontal 50%
magnify to 400%
reselct eliptical tool
count squares on each side
use arrow keys until all squares are equal
once it's line up use paint bucket to fill center hole
done
PS, I'm assumming you did the same thing for the outside ring too
Or it will not line up right if you don't -
I downloaded the trial this morning. When you create a new label you get a wizard that asks you to select label stock. What do you use for the R200?Originally Posted by papakilo
Thanks stiltman. I've only used PS for photo editing. Although I've used adjustment layers, it looks like I'll have to dig out my PS books to use PS to create this.
no books needed, just do itOriginally Posted by Michelle
now once you add your art work to new layers on top of the template, you're on your own
I just found a post that says you can select the Epson Stylus Photo 960 in SureThing.
layer -> newOriginally Posted by Michelle
label it art work
that'll get ya started
made it easy for y'all
my multi template
templates.zip -
stiltman, the only measurement I can get is cm, so I've just been dividing by 10 to get mm. However, 22mm is 2.2cm (unless my metric is screwed up), and that seems awfully small.
So far, you've shown me 2 new PS tricks AND in one day. Congrats. Been a long time since somebody could do that.Want my help? Ask here! (not via PM!)
In PS 7 or CS for the eliptical tool, just type 118mm and click the next box, type 118mm and click back to the first box....Originally Posted by lordsmurf
When opening a new file, the drop down box should have;
pixels, inches, cm, mm, points, picas. Just choose mm
33x117 for ProDisc silver injet
22x118 for ProDisc white print to hub
15x117 is a hub label applyed to a regular printable cd/dvd
I found that opion for the eliptical and square by chance. I was just messing around and did it. Took me a little while later to firgure out how I did it they time before.
Actually, I don't use a perfect circle when I'm modifying my labels if I'm inporting from my scanner. Seems my scanner is a little off
I have to set it to H 118 W116 to trim the outsides. Then I copy and paste it into a new file. Then I stretch it out to 118. Pain in the butt I know...I usually don't trim the inside hole -
Using PS6 here.
Yeah, I knew about the eliptical tool, it was exact sizing I did not know. But I have to right click and go to a menu, which bring up exact sizing to input numbers. I did not know that was possible, dug around where you said set numbers.
I usually do guiders by eyesight or exact measure. The new guides from the dropdown menu is in cm/in/etc, not % ... but manually typing in 50% worked too. Other new trick.
What I was saying is that 22mm seems awfully small, too small, for the hole. Are you sure that's the hub hole measure?Want my help? Ask here! (not via PM!)
I can verify that. I have been using 22mm on the Prodisc Hub Printables.Originally Posted by lordsmurf
This is the Photoshop template that I use.
http://ftp27.hyperceptive.net/chute/DVD_Label_%20Template.zip
How to edit and make up a prog off a DB disc Q?
By Murray in forum Newbie / General discussionsReplies: 1Last Post: 20th Feb 2012, 02:42 -
Copping Disc - Disc Data Recovery Software.
By Teac23 in forum DVD RippingReplies: 5Last Post: 1st Oct 2010, 20:06 -
DVDslideshowGUI - How do I make AVCHD disc?
By PeterDuke in forum ProgrammingReplies: 7Last Post: 4th May 2010, 09:34 -
How to make one .avi from a two disc set?
By TheMoreYouKnow in forum Newbie / General discussionsReplies: 8Last Post: 24th Sep 2009, 08:52 -
Epson R200 printer and DVD art
By dymx in forum ComputerReplies: 4Last Post: 8th Jul 2008, 11:57
