I've seen and read the tutorial on the MediaChance website, tried making my own and followed it step by step. The difference is that i've got only 1 subtitle stream, while their tutorial made it for 2 subtitle streams.
I got lost after the point when the tutorial inserts the VM commands. Since i had only 1 subtitle stream, i had to match the VM commands to make it somehow work. I think I got my VM commands all wrong so I'm not exactly sure how to debug it.
Anyway, I was able to burn it onto a disc then I found out the menu doesn't work properly. Selecting any option on the menu doesn't change the video at all. The video just played with its default settings.
Any help would be much appreciated.
If this is a stupid post, tell me bluntly so I'm not wasting anybody's time
If it is stupid, could anybody suggest an easier way to create the menu selection for multiple audio and subtitles?
Thank you in advance!
(my head is spinning. been at it half the day.)![]()
It is not a stupid post.
The easiest way to select a subtitle is to create a button for each subtitle on a VTS (not VMG) menu. Example:
English
Spanish
Kentuckian
Play
Right click on each button and find the menu item link ->set subtitle->subtitle 1 (or 2..3..4...5)
Then create a button "Play" and link this to the movie. Select the subtitle button first then select "Play".
Forget about VM commands until you feel comfortable with DVD Lab Pro (DLP). Then we can dive further into complex VM programming that will make your head spin.
As humans we like to count starting at one. For programmers they like to start at zero....Thus examples in VM will access the first subtitle as 'zero' (0) versus one (1).
Last word of advice:
Make sure your subtitles do not cross chapters. The start and end times must be between chapters in your movie.-----------------------------------------------------
There is a reason why God gave us one mouth and two ears!!! -
oh,
The same approach can be done for the audio stream. Notice the button links available to you.....-----------------------------------------------------
Thanks for the replies! Yeah i've tried those methods and they worked great
but i'm still trying to make those cool buttons that stick when you select them hehehe still trying to get the hang of those codes
DVD Lab Pro - Import .SSA subtitle problem
By satan999 in forum Authoring (DVD)Replies: 3Last Post: 27th Jan 2011, 07:21 -
DVD Lab Pro menu help
By stantheman1976 in forum Authoring (DVD)Replies: 12Last Post: 27th Jan 2009, 17:27 -
Audio Problem with VMG menu in DVD Lab Pro
By SCDVD in forum Authoring (DVD)Replies: 5Last Post: 22nd Apr 2008, 22:15 -
DVD Lab Pro Subtitle Mapping issues
By ArtOfLosingMFZB in forum Authoring (DVD)Replies: 1Last Post: 2nd Feb 2008, 20:41 -
Can you keep menu audio playing with Dvd-lab pro?
By jimjones2007 in forum Authoring (DVD)Replies: 7Last Post: 29th Aug 2007, 20:53
