Can anyone know sofware which allow me changing file mpg?
Try to frame your question clearly with details on what you've done and what you want to do. No one here is psychic...
I have some mpg file. It also a still image and I want to change and to convert it to some other format such as jpg. Do you know any sofware can do like this?
Open the mpg in tmpgenc, select File->output to file - > sequence bmpg/jpg
or
Open the mpg in virtualdub-mpeg2, select File->Save image sequence.
If you just want one screenshot you can use Media Player Classic, File->Save image. -
Thanks.
But I used tmpgenc , it can't open open mpg file
Used Media Player Classic and saved to jmp file but when I can't open that jmp file
Converting an MPG file to an ISO file.
By MrZ in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 13th Dec 2009, 22:58 -
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 14:51 -
toast won't do wav, so using mpg file instead of m2v file gets round that?
By jboyd in forum ffmpegX general discussionReplies: 12Last Post: 16th Nov 2007, 15:08 -
Spliting large mpg file into clips and saving each clip as a mpg file ?
By denise4gb in forum EditingReplies: 1Last Post: 6th May 2007, 18:52
