    Jan 2003
    Caguas, PR
    Greetings.
    I'm planing on using a P4 3000 MHz, 1GB RAM, Nvidia GeForceFX 5200 128MB, a 40GB HDD for OS and software and a 200GB 7200 rpm ultra ata 133 Maxtor HDD for the video, Pioneer DVR-108, Canopus ADVC-100 with Windows XP Service Pack 1.
    I was wondering how can I improve the performance by disabling services, using or not using a swap file, etc. I know that I need to enable DMA, and disable eye candy as much as possible.
    What would be your suggestions and tips to improve performance?
    I will be controlling the computer from a Win98 PC using VNC on a two PC LAN.
    Thank you for you help.
    Take Care.
    JuanMa
  2. Member sacajaweeda's Avatar
    Sep 2003
    Would I lie?
    "There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
  3. With your specs you should have no problem capturing video without doing anything. I am only running P4 1.8 Ghz w/512 RAM and have no trouble (unless the NAV begins a full system scan on it own). I have to remember to disable NAV during capturing.
    Xp will enable DMA on its own if the devices support DMA.
    If it works, don't fix it.
    Jan 2003
    Caguas, PR
    Thank you sacajaweeda and dxj40c.
    Take Care.
    JuanMa
