I am shopping for a new DVD writer, probably a LG or NEC.
Since they are both dual-layer burners, does this mean that I can backup a movie DVD without any editing ?
Hello,
Yep.
Just use dvd decrypter. ISO READ. Then open the iso file and use ISO WRITE.
It will be a 1:1 for a dual layer burner.
yes! but dual layer discs are very expensive at the moment, costing about half the price of an original disc, so it's kinda not worth using them at the moment..
DVDDecrypter ISO Read/ISO Write .....
... And plenty of cash to spend on media
If in doubt, Google it. -
Yes. DVD decrypter works fine, but I usually use AnyDVD (to defeat copy protection) and then just copy on-the-fly with Nero. It takes 20-25 minutes on Verbatim DL disks at 4x on my Pioneer 108. Either way works great.
The only drawback right now is the cost of the double layer media. It's coming down though. I bought my first DL disk 2-3 months ago for $13. I just got some more for $5-6 (after rebate). I'm really hoping to see them get down to around $2. -
You could try my method, that doesn't involve buying software as it uses free software, until the price of DL media drops to a realistic level
http://www.thescrapyard.pwp.blueyonder.co.uk/files/video/using%20freeware%20utilities%...r%20movies.htm
It can use single or DL media, just choose different settings
I bought use the NEC 3500 and retired my Pioneer A05, simply because the reviews said it was the best for quality of burns, might not be the fastest, but I'd prefer quality over speed
Backup Blu-Ray Movie only to BD-R 25gb?
By brad2157 in forum Blu-ray RippingReplies: 54Last Post: 9th Nov 2012, 00:12 -
How do I backup this movie and maybe change menus?
By leopardx in forum Blu-ray RippingReplies: 3Last Post: 6th Jun 2009, 10:10 -
trying to backup the simpsons movie
By etrin in forum DVD RippingReplies: 30Last Post: 12th Oct 2008, 08:14 -
Goal 2 movie backup
By paul_pompey in forum DVD RippingReplies: 2Last Post: 2nd Feb 2008, 04:54 -
Resident Evil First movie ...Not Apocalypse the 2nd movie backup issue!!!
By vanc in forum DVD RippingReplies: 0Last Post: 19th Oct 2007, 11:33
