  1. Can anybody tell me if there is a region hack for the Naiko N2051 player please, Thanks in advance
  2. Hmmm...buy it from makro?
    I couldn't for the life in me find a hack for it....nice build quality tho...it was surprisingly solid.
    I got one last week but ended up takin it back for a philips 612 cos of svcd 'issues'.
    The Naiko was good in that it could play mpg's from anywhere on a cd with its menu thing..and mp3's were good.
    I could not get it to play svcd's tho..and it says it can on the front of the thing.
    Good luck with the hack tho..I have searched the four corners of the net to find one and couldn't
    ...cue someone posting one now and making my net search skills look lame
  3. I found it at last, here it is in its full glory and it works!!
    on handset..
    press setup, stop,prev,next...
    then use right cursor to move across to region panel, use down cursor to move to 'bypass' press play
    The press setup again to exit.
    you can also disable macrovision in this menu
