Minnetonka Discwelder Chrome v2.06 produces an image file with extension *.dim
I tried to convert it to iso but my pc players do not play only cyberlink powerdvd prompted to download CPPM audio features to play the image file
other players refused to open the file
Is there any way to convert or verify if this image file is payable and plays right ?
thank you
Thanks I did exactly that but all I got is garbled soundOriginally Posted by daphy
besides the resulting dvd was huge comparing to the file -
I was able to load it with Alcohol to a virtual drive and then just play that like any other DVD. If it doesn't work, then I would assume that the DVD will not work in a standalone player.
Hope that helps... -
I have a silly question about this. I'm not sure what is trying to be accomplihed here. With Diskwelder you are making a DVDA. DVDAs, just like SACDs won't play in standard DVD players. If what you want to do is make something that plays in standard DVD players, it looks like you may have spent an awful lot on the software, but want to make something for older players. To play these new discs you must purchase a new audiophile deck. I just got Pioneer that received some great reviews for only $99.00.
Minnetonka is very helpful, i suggest you contact them
Minnetonka Discwelder Chrome v2.06 owns a 'mirror' option, which allows you by a single click to transform the whole DVD-Audio project (Audio_TS) into a DVD-Video (Video_TS) as AC3 -> now you got both on one disc!If what you want to do is make something that plays in standard DVD players
If your DVD-Player supports DVD-Audio it uses the AOBs, if not (like most of those players) it uses the VOBs
I hope this time I catched the point 8)
bye Daphy
BDR produced on a 4.6 GB file...fritzi?
By New Bee in forum Blu-ray RippingReplies: 9Last Post: 4th Feb 2011, 11:38 -
Video with L/R tracks to DVD with 2 channel audio tracks
By Downloader in forum Authoring (DVD)Replies: 2Last Post: 22nd Aug 2010, 02:56 -
[b][url]TEST! TEST TEST! WHAT"S THE BEST?!!!!!!!111111
By lordsmurf in forum TestReplies: 0Last Post: 2nd Aug 2010, 03:30 -
VHS Camera Produced Strobing-Can I Remove It?
By Anonymous8743 in forum Capturing and VCRReplies: 0Last Post: 23rd Feb 2009, 20:01 -
ffmpegX says it's finished converting, but nothing is produced!
By alexliz in forum ffmpegX general discussionReplies: 3Last Post: 12th Dec 2008, 15:16
