I have many VHS tapes and want to convert them to DVD. I would like to know what bitrate (max.,min., and avg.) to set in mainconcept encoder. I don't want to lose quality and I am sure the default DVD setting in mainconcept (Max.8000, Min. 2500 and Avg.6000) are too high. I am looking for settings that will put the maximum amount of VHS footage on a DVD disc without losing quality.
Doug
I dont think that you need more than 4000 average, mabe 3500 is ok for VHS
In any case you can calculate here the amount of footage you want to store in a DVD changing the bitrate : https://www.videohelp.com/calc.htm
For MC I use SEarch method 11 and shearch range 23 and Noise reduction=0. Audio bitrate 192 (is more than enough). AutoGop =VCSD . 2pass encoding is more accurate but takes too long to encode....
You have to make short test samples with various bitrates to see the differences....KONX OM PANX -
IMO I think we need to go a bit deeper than your question commands. For starters, "maximum amount of VHS footage on a DVD disc without losing quality" is almost a "best of both worlds" scenario. In order to "juggle" this, there's quite a bit of trial, error and sacrifice.
These are the things we can play with:
frame size/video bitrate
audio bitrate
Many say that you are better of using 352 * 480/576 (Half D1) for VHS. Using this frame size allows you to drop the bitrate considerably with no noticable effect on quality. Using Half D1, you could get away with CBR 3500 or thereabouts, which is about 2.75 hours w/ 192 audio. If we really wanted to extend the playing time, We need to look at 2-Pass VBR. 4 hours would require an average of 2344kbps w/ 192 audio. Dropping to 352 *240/288 might be OK for you, and will allow you to cram even more on a DVD. 6 hours requires a bitrate of 1500 w/ 192 audio.
... And then we can drop the audio to 128kbps ...If in doubt, Google it. -
352x480 = 3500-5000 max
avg VBR numbers can be 500-1000 lower
720x480 = 7000-8000 max
avg VBR numbers can be 1000-2000 lower
min can be whatever, 0 is fine, good software never dips that low anyway.Want my help? Ask here! (not via PM!)
I have just transferred a 90 minute VHS tape, as well as a two minute restoration comparison at full PAL res. Using Mainconcept as the encoder with settings of min 4200, max 8400, avg 6000 I was able to fit the whole shooting match, including 4 static menus in about 3750MBs. Pushing the avg up to 6500 took up more space, but had not effect on quality. At full res, I wouldn't want to put more than 2 hours on.
Read my blog here.
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 16:52 -
NTSC Vhs to dvd quality
By victoriabears in forum Newbie / General discussionsReplies: 11Last Post: 11th Jul 2010, 21:31 -
S-VHS to DVD - with maximum quality
By Tafflad in forum Capturing and VCRReplies: 5Last Post: 23rd Nov 2009, 06:29 -
VHS -> DVD question on quality.
By Oob in forum RestorationReplies: 9Last Post: 19th Apr 2009, 00:40 -
How to get DVD Quality on a VHS Transfer?
By Nitro89 in forum Capturing and VCRReplies: 28Last Post: 10th Nov 2007, 01:26
