I downloaded DVD2SVCD and I didn't like it. So I uninstalled it and all of the components that comes with this program. After I did this, I can't capture anything from my Camcorder anymore. None of my programs can. One of the programs say that I miss a didgital codec that is included in DirectShow and in Windows MediaPlayer 9.0.
I don't know why DVD2SVCD uninstalled this codec cuz when I try to update DirectShow it says it is updated and all of its components.
My question is... If you know what kind of digital DirectShow codec this is about and where to find it speratley or how I can get rid of this problem in any other way PLS TELL ME!
Or give me some links where I can get all codecs I need to be able to capture with my cam again! I don't want to re-install my system.
I must honor the code
http://www.microsoft.com/windows/windowsmedia/download/default.asp
Where it says select download choose codec installation packages.
Should be the last one on the page. -
Originally Posted by Shadowmistress
Any other ideas?
I happen to know it is a codec that comes with DirectX and with DirectShow. The problem is there is no way I can re-install DirectX what I know of. Or do anyone know of any way to uninstall or re-install DirectX somehow?I must honor the code -
http://www.microsoft.com/downloads/details.aspx?FamilyId=0A9B6820-BFBB-4799-9908-D418C...displaylang=en
Download the full DirectX 9.0c installer and reinstall. Should install right over the current version even if its the same in my experience. -
Originally Posted by Poppa_MethI must honor the code
Missing Codec?
By jimbb in forum Newbie / General discussionsReplies: 7Last Post: 4th May 2011, 14:54 -
wmv missing codec
By uglijimus in forum Video ConversionReplies: 4Last Post: 11th Jul 2009, 01:20 -
Missing a codec?
By jnojr in forum Newbie / General discussionsReplies: 5Last Post: 2nd Dec 2008, 17:24 -
Codec missing
By breeze9 in forum Newbie / General discussionsReplies: 2Last Post: 29th Jan 2008, 21:08 -
Missing Codec
By arileysr2 in forum Newbie / General discussionsReplies: 1Last Post: 9th Jul 2007, 13:13
