Results 1 to 9 of 9
  1. hi everyone i wonder if someone could help. ive just tried to backup my copy of garfield and not one program will work dvd shrink fails, dvd ripper fails and clone dvd says it is css protected, any ideas anyone.
  2. Aging Slowly Bodyslide's Avatar
    Feb 2002
    A Different Timeline
    Normally you can try playing the DVD on your PC with PowerDVD, then use Dvddecrypter or DVDshrink after that.
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    What are the exact error messages ?
    If in doubt, Google it.
  4. clone dvd says its css protected so will not copy, all other just freeze my pc . its the only dvd that does this as i have tried others as a check
  5. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Have you tried ripping it to your hard drive using DVDDecrypter or Smartripper ?
  6. smartripper freezes as it begins to read the ifos, dvd decrypter puts it on my hard drive but i must admit its a program ive found difficult to use as i only want to extract the movie.if you want to extract the movie you have to manually select smaller files so you can burn the eventual dvd, ive found this quite difficult.
  7. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    If you're going to use DVDShrink in reauthor mode or CloneDVD to separate just the main movie, I think you need to extract all files , otherwise your IFOs will be up the shit.
  8. if your going to use clonedvd, it doesn't remove the css protection. you have to have an additional program in the background. Try using "AnyDVD" at www.slysoft.com
    Nov 2003
    Moreno Valley, Ca
    Used dvdshrink 3.2 full backup with no problem
