I am using an Avermedia USB2.0 video capture device for capturing VHS video tape recordings. The capture software with it is the Neo DVD software which I have read is 'bad' - has selection for good, better, or best quality (1x, 2x, 4x file sizes for the same segment of tape). However, I have had, at least marginal, success with it. I have 2 questions:
1. A 2 hour movie will fit on about 2/3 of a DVD if I capture in 'better'. Capturing in 'best' requires approximately 75% compression (using DVDSHRINK) to fit on a DVD. Should I capture in best and compress or capture in better and use no compression to obtain the least loss of picture quality?
2. Is there better software available that will work with the Avermedia device? For capturing movies recorded (on VHS tape) directly from a cable or satellite feed, the software needs to be able to provide contrast and brightness correction while capturing (or else I need to know what software to use to post-process the digital file to correct the brightness and contrast).
Regards,
John
Results 1 to 1 of 1
Avermedia capture HD using firewire?
By Zachash in forum Capturing and VCRReplies: 3Last Post: 7th Jul 2011, 15:49 -
AverMedia C027 HD Capture Low Audio
By XmnwildX12 in forum Capturing and VCRReplies: 3Last Post: 29th Jun 2011, 20:03 -
Help watching tv on Avermedia HD DVR capture card
By mason dixon in forum Newbie / General discussionsReplies: 3Last Post: 28th Apr 2011, 11:00 -
AVerMedia AVerTV Capture HD with GraphStudio problem
By feeltherock in forum Video Streaming DownloadingReplies: 0Last Post: 18th Feb 2010, 12:47 -
Who makes the best USB2 capture card for under $100?
By Haopengyou in forum Capturing and VCRReplies: 5Last Post: 7th May 2009, 16:52
