okay this is a little tricky. I'm not using the basic vcd NTSC template. i tweaked it a bit to use a higher bitrate and use color correction and what not to help on the brightness. one thing is bad. I CANT KEEP A MOVIE IN LETTER BOX FORM when i turn it into MPEG. it will be letter box on windows media player, but once i use it on a vcd/dvd prog (e.g.; winDVD) or on my dvd player it will cut off the sides and make it look horrible ( i think it stretches it a bit). I AM DIEING FOR HELP ON THIS!!! PLEASE HELP ME! Thanks a TON!
Results 1 to 12 of 12
Well ...
I'm a step behind you. How do I get a DIVX file into TMpegEnc to begin with. It keeps telling me that the file is not supported. -
clunk..
to use the new tmpg u have to use the old divx (3.11a)..it doesnt work with the new one for some reason.. -
Thanks howie,
Now another newbie question. How do I load the older Divx codec (and where can I find it?)? -
Ok, after opening my eyes, I see the old codec is on the tools page. How do I point TMpegEnc at it tho?
ya dont..
wat i did was just uninstall divx4 and put in 3.11 then now it works fine -
I just tried that (even rebooted before installing 3.11a) and I still get a can't open/unsupported error message. The file plays just fine in Media Player with either version of the DivX codec. I'm using the newest download of TMpegEnc ... should I try an older one?
OK, thanks for all your help ... I found the trick in the TMpegEnc conversion page. Setting DirectShow priority to 1 did the trick.
You could also use the old TMPGEnc12A which works with whatever DivX codec (I have 4.01 installed and it works fine). The old TMPGEnc12A is accessible from the Tools page.
BLaRmuS, if you still haven't work out how to keep the letterbox format (the original question) all you need to do is...under the 'Advanced' tab in TMPGEnc make sure that the 'Source aspect ratio is set to 1:1 (VGA)and the letterbox format will remain the same when encoded.
Clunk,
If you process the DIVX (version 4.xx) through Virtualdub
(both video and audio on direct stream copy) You can use
this outputfile in TMPGEnc.. (Last version)
This solved the same problem I had.
Good luck.
<font size=-1>[ This Message was edited by: Borgster on 2001-11-30 04:53:51 ]</font> -
Borgster
I have never encountered the problem they are talking about, because I have been running all my Divx's through Virtualdub ever since I have an audio encoding problem with TMPGEnc. I don't have any problems at all now. Cool.....
Converting Divx w/ Vorbis audio to Divx w/ MP3
By tachyon2u in forum AudioReplies: 3Last Post: 23rd Feb 2008, 23:35 -
Problem converting audio of VCD MPEG-1 to author DVDs
By Greycat in forum Video ConversionReplies: 6Last Post: 16th Jan 2008, 16:28 -
problem converting mpeg 1 to divx
By goingape in forum Video ConversionReplies: 11Last Post: 9th Jan 2008, 14:17 -
Converting HD (DivX/MOV/WMV etc) to DVD or DivX ???
By snadge in forum Video ConversionReplies: 32Last Post: 8th Jan 2008, 05:48 -
No sound when converting muxed mpeg-1 file to AVI DivX!
By mute82 in forum ffmpegX general discussionReplies: 5Last Post: 25th Oct 2007, 12:56
