Hey,
How do you format a hard drive ''COMPLETELY''
So no-one can ever retrieve anything that was on the hard drive...
Thanks in advance![]()
Results 1 to 30 of 48
Hello,
Don't you need to write it with dummy data and then format it again to ensure that the original data is REALLY gone?????
That is what format /u does.Originally Posted by yoda313
It is an unconditional format and writes over the entire drive with 1's and 0's, thus completely erasing what was previously on the disc. -
Low Level Format Utility will totally erase hard drive?
How long does it take?
Where do I find the utility... -
The time depends on the speed and size of the drive.Originally Posted by werewolf_02
Get the utility from the drive manufacturer's website ..probably under "Support"
Or do as bazooka suggested using a DOS command. -
Ok thanks, but there doesn't seem to be a utility for that on the medion website.
The '/u' would I have to change the 'u' to my drive letter? -
No. The full command would be:Originally Posted by werewolf_02
format c: /u
or change the c: to d: or whatever the drive letter is
Use a dos floppy and type in the command
a:/format c: /u -
Ok, this is for a different computer I am doing this, it had two drives partitioned. So I could format normally and have just one c drive, then I would use the dos menu and type 'format c: /u'
This will totally erase everything that has been on the computer? Its had loads of stuff, and been formatted many times...its about a year old. -
Yes, it will completely remove everything.Originally Posted by werewolf_02
Then I suggest you use a low level format utility that was suggested earlier.Originally Posted by werewolf_02
Floppy drives are always good to have.
This is one reason here to have a floppy drive, -
You could copy the dos files to a blank cd and use the cd to do the unconditional format.
Where will I get a low level format utility for my computer? It isn't on the medion website
Originally Posted by bazooka
I always wondered if you "leaned" the wrong way! :P
a:\ format c: /u -
Sorry....Originally Posted by tekkieman
I am only human and make mistakes. :P -
Sorry, I'm just finding humor in many things today.Originally Posted by bazooka
It's the web's fault, bazooka. I am constantly doing that because that's what I'm used to.
Start by drilling holes throught the hard drive(platters) then insiterate it.Originally Posted by werewolf_02
I know for a fact that a large shipping company (starts with F and ends with EX) drills holes throught their laptop drives. Then they dispose of them.
JSB -
Boot up with a Win98 CD, boot from CD-ROM and 'Start computer with CD-ROM Support'.Originally Posted by werewolf_02
Type '$driveletter$:'
Type 'cd win98'.
Type 'format /?'. -
I think he wants to reuse the HD afterwards.Originally Posted by JSB
Let's limit the discussion to helpful information, OK?
Yes, I want to use the hard drive again if possible :P
I still can't find a low level format utility thats ment for my pc?
Ohhh wait, it will be the hard drive website I look at right?!
I look at the company that produced the hard drive? and not the pc? lol...
You got it. The HD mfg.Originally Posted by werewolf_02
Ach im stupid...right, the hard drive!
I'll open the pc up later and check which hard drive it is, then ill use the low level format utility for it.
Once ive done that, no-one can get it back, even with special programs?
Also, its a 160 gig hard drive, how long roughly will it take to low level format? -
I think people can still get it back with specialist knowledge, programs and probably equipment, even after a low-level format. They'd have to be the police though.
A low-level format should suffice for domestic purposes.
A 160GB drive will take a few hours to low-level format.
If you are really that keen to destroy the information, then total physical annihilation of the drive is a must. I can't imagine what sort of data would warrant that sort of action.
Cobra -
Good luckOriginally Posted by werewolf_02
unable to format external hard disc drive
By skorpinok in forum ComputerReplies: 9Last Post: 17th Aug 2011, 16:35 -
Best format to store DVD's on a hard drive
By robrpb in forum Newbie / General discussionsReplies: 28Last Post: 7th Sep 2010, 21:46 -
hard drive files to burnable format
By peacock in forum DVD RippingReplies: 2Last Post: 25th Mar 2009, 17:50 -
Format Hard Drive
By danl_9x in forum Newbie / General discussionsReplies: 2Last Post: 22nd May 2008, 18:34 -
Hard Drive won't format
By waheed in forum ComputerReplies: 10Last Post: 16th Mar 2008, 15:14
