  1. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    I think 512mb RAM is enough right now but I may want to upgrade sometime soon.
    I have a new EMACHINES Celeron 2.66ghz pc. How do I tell the specs of the RAM? I know the memory rating but not if its a pc2700 or other pertinent info.
    Is it printed on the CHIP itself? I only have one of the two slots filled so obviously the one stick is a 512mb stick.
    Can I run a program to analyze it or do I have to open up the case again?
    Thanks in advance
    Kevin
  2. Member Heywould3's Avatar
    Apr 2002
    always on the move
    sisoft sandra can tell you
    all mine have stickers on them telling if pc133 pc2100 etc.. if not get the numbers off the chip and google it.. i think sandra has a free/demo avail.. google that too.. its a great little info tool
  3. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    I'll check that out this week
    Kevin
  4. Member Dr. DOS's Avatar
    Sep 2004
    Mid Atlantic
    Or do a searches for AIDA32.... great little program that will tell you mfg and speed of your ram.
  5. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    Thanks dr dos
    I'll checks these out later
    Kevin
  6. Member Tool Man's Avatar
    N. Ireland
    I find that CPU-Z is the quickest way to find out.
    We'll be right back after these messages from Binford!
