I got this movie where the audio is out of sync with the video , for the 1st 40 something minutes its fine than after that its just goes out of sync for the rest of the movie
So I tryed to fix it with Virtualdub I extracted the audio (full processing) and the video away from each other so i had 2 files an audio and an video file
Then I converted it to mpeg using Tmpgenc I put the video file in the video source and the audio file in the audio source
I also tried to fix it another way with Virtualdub I went to framrate and changed it so video and audio durations match and it still didnt work
And after it was all done it was still out of sync does anyone know what the problem is and another way I can fix it
the audio is from an Avi file if that helps
if anyone can help me id appricate it thanks
nevermind i found a program called VideoReDo it worked great on my video and fast
got a question tho has anyone ever used VideoRedo is so are there any programs real similar to this cause its only a trial and way too expensive $50 dollars is to much expecially since i dont get this problem too much
So if anyone knows any cheaper or even free programs similar to VideoReDo QuickEdit could u plz let me know thanks ?
Fixing sync problem on rmvb
By gameroftheuk in forum Newbie / General discussionsReplies: 0Last Post: 27th Aug 2008, 21:16 -
Fixing SYNC on affected converted .VOB's....
By snadge in forum Video ConversionReplies: 4Last Post: 16th Jan 2008, 16:54 -
Sync issues after fixing with ac3fix
By mub6 in forum AudioReplies: 5Last Post: 24th Dec 2007, 07:56 -
Fixing some videos
By Broka in forum RestorationReplies: 22Last Post: 21st Dec 2007, 21:14 -
Need help fixing up already converted DVDs of old videos
By t_burrito in forum RestorationReplies: 1Last Post: 10th Jun 2007, 00:32
