i am going to film a short commercial for a school project. I am using or attempting to use final cut pro 4 to put it together. I still have yet to buy a small tutorial book for it but thats beside the point. Now i want to use a specific song for the commercial but only a part of it.
Is there a specific program for mac so that i could use only a part of the song? Say only 20 seconds of it? Say a program similar to Sound Forge for the pc. I think thats the name of it.
Any info on this would be greatly appreciated.
Amadeus can be grabbed for free although it is only a trial version. You can grab any part of a song with that software and save it as a separate file.
http://www.hairersoft.com/Amadeus.html -
You can accomplish that with FCP, iMovie, or QuickTime Pro. Your best bet would be to just use FCP since that's what you're already using. You need the song in AIFF format. Convert it with iTunes, iMovie, or QT Pro (I'm assuming that your song is MP3 or AAC). Import the AIFF into FCP. Double click the song in FCP, move the play head to the in point, click the 'Mark in' button. Move the Playhead to the out point, click the 'Mark out' button. File menu, Export, QT movie. If you can't do this, you REALLY need that bookOriginally Posted by drew6983
Thank you guys very much for helping me out i really appreciate it i will sample both and see which one works best for me.
FCP
MP3 - Batch export song number/song title/etc to ID2/ID3 ?
By ralf07 in forum AudioReplies: 5Last Post: 3rd Mar 2012, 01:51 -
A time-lapse video that writes the words to a song as the song plays
By radardetector in forum Newbie / General discussionsReplies: 3Last Post: 4th May 2011, 22:09 -
Very specific question regarding capturing multiple sources
By Acester47 in forum Newbie / General discussionsReplies: 0Last Post: 20th Jan 2011, 21:04 -
old mp3 song -purifying the audio
By sumeshkri in forum AudioReplies: 2Last Post: 8th Jul 2010, 23:59 -
making video of song lyrics, and adding a song...how?
By snafubaby in forum Newbie / General discussionsReplies: 6Last Post: 15th Mar 2010, 03:09
