Quick question, can I put an 8x AGP card into a motherboard with a 4x AGP slot.
Cheers
Yes I think they are all backwards compatible, it drops the card down to 4x -or- is it the other way around.
Yes, you can. I did this in my old Dell - the card will simply drop back to the AGP 4X standard.
Thanks guys
My MB only supports 4x.... what the difference? Throughput to the cpu?
Can I put a 4X/2X AGP card into a 8X/4X slot?
The 8X/4X slot is Version 3.0 AGP.
I think I can do this, but it's the opposite of the original question, etc. -
Yes it is the same theory as the card will still only run at 4x as if you had an 8x card in a 4x slot.
"ONE BY ONE THE PENGUINS STEAL MY SANITY"
Need recommendations re. AGP card(s)
By CBinSD in forum Newbie / General discussionsReplies: 14Last Post: 14th Aug 2009, 19:20 -
AGP Video?
By bevills1 in forum ComputerReplies: 6Last Post: 15th Jun 2009, 18:04 -
Strange AGP Problem ???
By blinky88 in forum ComputerReplies: 21Last Post: 14th Jun 2009, 11:47 -
MB with Agp AND PCI-E?
By Lucifers_Ghost in forum ComputerReplies: 5Last Post: 25th Apr 2008, 07:01 -
nvidia geforce 7800gs AGP V's geforce fx 5500 AGP
By stackner in forum ComputerReplies: 5Last Post: 15th Jun 2007, 14:22
