The process seems pretty straight-forward, I'll be burning my first vcd tonight using:
- Firewire DV capture and editing in VideoFactory to produce source MPG
- Convert to VCD MPEG1 with TMPGEnc
- Burn VCD (CD-RW) with NERO
The instructions on this site are very complete, with one exception - what format (codec, resolution, frame rate, aspect ratio, etc.) should I come out of VideoFactory in for best results? I tried pointing it at one of the captured DV clips, but it wouldn't read it, even after adjusting the priority of the AVI VFW plugin in TMPGEnc.
TIA,
- DannO
If you've got VideoFactory, you don't need to do the TMPGEnc step. Just make a VCD compatible MPEG from VideoFactory. To do this, go to the File drop down and click Render.... which will launch a dialog box. In there, select the VideoCD template. This is a good place to start. From there you can edit this template or create another to change from Good quality to Best, add motion blurr or whatever.
VCD to VCD back-up
By fiiido in forum Authoring (VCD/SVCD)Replies: 4Last Post: 29th May 2011, 12:39 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
