Hi, considering buying Premiere Elements since it looks strong enough at its low price point for what I want to do. I have one question tho, which stems from this in the videohelp.com review:
"It is absolutely true that your source media must be 720x480 or the associate PAL resolution. If is isn't, the tool assumes your souces has missing pixels and creates a distorted video with wide black bars on each side. " He goes on to say that analog source material, if imported, runs into these problems.
I was concerned because my original source material was Hi8 analog tapes. What I did was put them all on DVD's via my Panasonic DMR-E50, so now I want to take the video from the DVD's and put them on my computer, then edit them from there. Am I correct in assuming that this will work fine? Because the source now is my DVDs I have already made. Or am I going to get mass distortion etc?
720x480 is all it takes.
Your Panasonic (at least some of them) are 704x480, not 720x480Want my help? Ask here! (not via PM!)
You also have to remember, Premeire is not a native MPEG editor, you may have to convert the DVD video to an AVI file first.
VTMI have the staff of power, now it's up to me to use it to its full potential to command my life and be successful.
Adobe Premiere Elements
By willmington in forum Newbie / General discussionsReplies: 5Last Post: 5th Jul 2011, 04:14 -
Adobe Premiere Elements 7 keeps crashing
By NP11073 in forum EditingReplies: 7Last Post: 22nd Oct 2008, 02:23 -
Adobe Premiere Elements 2.0-mpeg4
By Mållgan in forum Newbie / General discussionsReplies: 3Last Post: 5th Oct 2008, 13:13 -
Adobe Premiere Elements 4 - How Much Memory?
By oldandinthe way in forum Authoring (DVD)Replies: 0Last Post: 8th Nov 2007, 15:05 -
By pepegot1 in forum EditingReplies: 12Last Post: 28th Sep 2007, 11:59
