I opened a movie in DVD Shrink a few days ago and in full disc the movie size was 2900 megs, when I went to re-athor to do just the movie it showed the movie as 5400 megs. Why the difference? There was only one version of the movie not two.
You are seeing the after compression estimates. If the disk has a lot of extras, then the movie has to be compressed more, making it smaller. When you reauthor and take just the movie only, you don't need to compress it as much, and so it appears bigger. In the mpeg world, bigger is better (up to a point).
If it is showing 5400, check the preferences to see what size the target disk size is. 5400 is too big to fit on a single sided disk.Read my blog here.
How to do a dvd shrink containing only the movie without menu's etc
By vain in forum Newbie / General discussionsReplies: 3Last Post: 19th Apr 2009, 09:57 -
how to shrink a movie to fit a dvd 5?
By just in forum Newbie / General discussionsReplies: 2Last Post: 30th Oct 2008, 00:58 -
Shrink DVD movie
By Bookmaster in forum EditingReplies: 3Last Post: 24th Dec 2007, 07:41 -
Tutorial: Using DVD Shrink to extract ONLY THE MOVIE
By RogerTango in forum User guidesReplies: 3Last Post: 11th Dec 2007, 22:35 -
how to shrink a movie with DVD Shrink?
By php111 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2007, 18:59
