  1. I have a bin file that I extracted mpeg using Isobuster (extract but filter only m2f2 mpeg frames). I then burnt to dvd using Windvd, the resulting quality was good but the movements on screen were jerky. Does anyone know how to fix the problem.
    WinDVD is playing software, not burning software
  3. Member Forum Troll's Avatar
    Oct 2003
    Right behind you
    He means Win DVD Creator.
    http://www.intervideo.com/jsp/WinDVDCreator_Profile.jsp
    You are in breach of the forum rules and are being banned. Do not post false information.
    /Moderator John Q. Publik
  4. ok, so I'me using creator ---this still dosn't answer my question. Do you suggest another tool to fix the problem
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    are you doing vcd to dvd ? or svcd to dvd???
    It's re-encoding however it feels is best. Not good. Get a real encoder and set your own final encode settings, based off the source file settings. All you really want to change is resolution, leave others alone, and keep it within DVD spec.
