I've read here that when you have two DVD drives, one a R/RW and one a ROM, you should have the R/RW set up as the master.
I've already set up my drives on the secondary cable but the DVD ROM is set as master. My question is can I switch the drives without having to uninstall/reinstall the drivers?
Thanks in advance.
Yes. Master or slave has nothing to do with the drivers. Actually, you shouldn't have any drivers to install. Optical drive support is built into the OS.
Nothing can stop me now, 'cause I don't care anymore. -
Listen to viral.
He knows what he is talking about.
The optical drives shound not need drivers to be installed.
Will switching from IDE to USB HD be to slow?
By happydog500 in forum ComputerReplies: 6Last Post: 18th Dec 2009, 00:03 -
Switching TWC-NYC channels with a 'cable eye'
By xmiinc in forum Newbie / General discussionsReplies: 2Last Post: 28th Jun 2009, 15:02 -
DMA changes to PIO for all 3 Dvd drives, even after unistalling IDE driver
By Denvers Dawgs in forum ComputerReplies: 3Last Post: 2nd Mar 2009, 14:45 -
About IDE to USB adapter cable
By AusTaylor in forum ComputerReplies: 7Last Post: 4th Feb 2008, 00:18 -
any deals on Seagate 400-500G internal IDE hard drives this week?
By JohnnyBob in forum ComputerReplies: 4Last Post: 15th Oct 2007, 13:45
