Ive got a ISO file I tried to burn to Taio Yuden DVD-R disc and it keeps failing everytime, Ive tried to use Sonic Record Now Deluxe and also DV Decrypter.
Is the Sony DRU510A not able to burn to these discs as I sent the discs to my cuz and he has the same burner and same problem, he cant burn anything to them????!?!?!
Firmware is up to date at SONY DVD RW DRU-510A 1.1a
The discs are not faulty as they burn fine on my Pioneer A07XLB.
The TYG02 are genuine as they are from SVP......
HELP!!!!!!!
INFO given by DVD Decrypter.
Current Profile: DVD-R
Disc Information:
Status: Empty
Erasable: No
Free Sectors: 2,298,496
Free Space: 4,707,319,808 bytes
Free Time: 510:48:46 (MM:SS:FF)
Supported Write Speeds: 1x, 2x, 4x
Pre-recorded Information:
Manufacturer ID: TYG02
Physical Format Information (Last Recorded):
Book Type: DVD-R
Part Version: 5
Disc Size: 120mm
Maximum Read Rate: Not Specified
Number of Layers: 1
Track Path: Parallel Track Path (PTP)
Linear Density: 0.267 um/bit
Track Density: 0.74 um/track
First Physical Sector of Data Area: 196,608
Last Physical Sector of Data Area: 0
Last Physical Sector in Layer 0: 0
heres the error i get.............
I 01:12:53 DVD Decrypter Version 3.5.1.0 started!
I 01:12:53 Microsoft Windows XP Professional (5.1, Build 2600 : Service Pack 2)
I 01:12:53 Initialising SPTI...
I 01:12:53 Searching for SCSI / ATAPI devices...
I 01:12:53 Found 1 DVD±RW!
I 01:13:39 Operation Started!
I 01:13:39 Source File: D:\TGBM.ISO
I 01:13:39 Source File Sectors: 2,056,320 (MODE1/2048)
I 01:13:39 Source File Size: 4,211,343,360 bytes
I 01:13:39 Destination Device: [0:0:0] SONY DVD RW DRU-510A 1.1a (E(ATA)
I 01:13:39 Destination Media Type: DVD-R (Disc ID: TYG02) (Speeds: 1x, 2x, 4x)
I 01:13:39 Destination Media Sectors: 2,298,496
I 01:13:39 Write Mode: DVD
I 01:13:39 Write Speed: 2x
I 01:13:39 Test Mode: No
I 01:13:39 BURN-Proof: Enabled
I 01:13:39 Filling Buffer...
I 01:13:40 Writing LeadIn...
E 01:14:54 Failed to Write Sectors 2240 - 2271 - Power Calibration Area Error
I 01:14:54 Synchronising Cache...
E 01:14:54 Failed to Write Image!
E 01:14:54 Operation Failed! - Duration: 00:01:15
I 01:14:54 Average Write Rate: 0 KB/s (0.0x) - Maximum Write Rate: 1,019 KB/s (0.7x)
Verb media and never a problem....
~~Pioneer A07XLB~~
~~Sony DRU510A~~ -
I also use the dru-510a (1.1a) and burn almost exclusively Taiyo Yuden 8x and before that 4x from Rima. I also burn Japanese Fuji disc with the TY media code....all with no problems.
I am using DVD Shrink, and then NTI DVD Maker Platinum for the burning software. Before I used NTI, I had a few problems with Nero and many problems with BurnAtOnce.
NTI software works out perfectly EVERY time. It might be your software. -
Have you cleaned your laser lens recently?
I'd tend to suspect the Sony burner before the TY media
Question about either of my Sony drives being able to burn dual layer discs
By Puppets86 in forum DVD RippingReplies: 51Last Post: 9th Jun 2010, 19:04 -
Burn DVD / Divx for SONY DVP-NS708H
By yan_pap in forum MacReplies: 3Last Post: 5th Apr 2009, 06:58 -
How to edit Sony m2ts files to burn to blu ray disc.
By tchambers in forum Authoring (Blu-ray)Replies: 23Last Post: 11th Nov 2008, 23:53 -
Can you burn directly from Sony hdr- sr1 to blue ray disc, How?
By pistol pete in forum Authoring (Blu-ray)Replies: 1Last Post: 12th Mar 2008, 04:49 -
burn video from sony hdr-1 to blu ray disc
By pistol pete in forum Newbie / General discussionsReplies: 0Last Post: 2nd Mar 2008, 22:45
(ATA)
