  1. Is there anyway to get DVDShrink to create a subfolder using the disc label as the subfolder when outputing to the output folder. Like the Semi automatic feature in DVD Decrypter.
    Thanks.
    Kizer
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Mine does by default ???
    If in doubt, Google it.
  3. How do you setup do to that. For example I want it to go to E:\Movies\Output\DiskLabel automatically.
    Thanks.
    Kizer
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    When I said "by default" I meant that I had no idea how it managed to get set up like this. I suspect that I've specified C:\movielabel for a movie, and then the next time I've used it, it's picked up the C:\ part and just appended movielabel. Set yours up to where you want the first one to go, then go to do another one and see if it pulls through the E:\Movies\Output bit and appends the movielabel. I suspect it will
  5. Thanks for the reply, I will give it a try.
