Closed Thread
Results 1 to 9 of 9
    May 2004
    Thanks for everyone's help before. I am still looking for the best way to capture a 30 second clip off of a commercial dvd. I downloaded DVD shrink and took the .vob file and tried to convert it to a mpg file and an avi file and with either format when I dropped it into adobe premiere i lost the sound because the dvd was in ac3 format. I could use dvd decryptor but i would have to do the whole dvd (to my understanding). I just want a 30 second snipit of the movie. Any other suggestions or ways that I can get my DVDshrink clip work (with volume) in premiere.
    Thanks in advance for your help
  2. adobe premiere
    Cant Handle Ac3?
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    So convert the AC3 out to PCM WAV.
    If in doubt, Google it.
    May 2004
    Thanks for the reply.
    How do i capture the sound seperately?
    Do I capture the sound off of the dvd or the vob file that is created from the dvd? If I have to capture it off of the dvd then won't it be a bear to sync the 2 clips if the start and stop points are different if i have to use 2 seperate programs?
  5. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    What I would do from the very very start is use DVDShrink in reauthor mode and use the start/stop mode to isolate the 30 second clip you require. Do you just need the 30 second clip and that's it, or do you need to do further editing on top of that ?
    https://www.videohelp.com/forum/viewtopic.php?t=242893 might be able to help with the AC3 --> WAV conversion
    Besweet for AC3 to WAV. Easy. Use the GUI too.
    May 2004
    I have obtained the 30 second clip from dvd shrink and found that its only option is the ac3 option. I want to take that clip and drop it into premiere pro to put it into a family video that I am making for christmas.
    I tried to follow the thread you posted and it is much appreciated, there seems to be alot of options. I wanted to find the most streamlined way of doing this.
    Thanks so much to this group it has been a savior for projects past.
    Jeff
  8. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    BESWEEEEEEEEEEEEEEEEEEEEEEEEET. Demux the MPG, then convert the AC3 to WAV.
  9. Член BJ_M's Avatar
    Jul 2002
    Canada
    one thread is enough ... do not double post please
