This may been asks before, I just want to know.
I like to make my own custom DVD buttons.
So is there a software to make custom dvd buttons?
I use encore DVD 1.5. Basically, anything you can create in photoshop (including rollover buttons) can be directly imported into encore.
Photoshop PSD's are used by many.
find out what graphics format your authoring software will import. use any graphics editor that will produce that format.
I use DVD Lab, which will import .png graphics (among other formats) so I usually use Illustrator and Photoshop to put together graphics, save them as .png and import into DVD Lab.
don't have Illustrator or Photoshop? Try Inkscape and The Gimp, freeware open-source apps that have many of the same features.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
I have been trying to modify some of the Encore 1.5 buttons but have not had any luck. I have a 5.5 version of PhotoShop and wonder if that is my problem?
Can anybody point me to more info? -
Real Draw Pro and DVD menu Studio do the job well.Originally Posted by Timmychuck
Of course if you want to do it the best way use Photoshop and/or Illustrator.
Editing the commands of the buttons on the DVD menu?
By rone in forum Authoring (DVD)Replies: 24Last Post: 18th Jun 2011, 05:35 -
GfD - Buttons invisible after creation on DVD
By michcio in forum Authoring (DVD)Replies: 4Last Post: 2nd Jul 2009, 18:22 -
Active Buttons on DVD Menu
By dartmanx in forum Authoring (DVD)Replies: 1Last Post: 22nd Jun 2009, 05:53 -
Re: index buttons when making a DVD
By tomcat862 in forum Authoring (DVD)Replies: 1Last Post: 22nd Feb 2008, 05:24 -
Is it possible to make animated buttons and info box?
By leffe in forum Authoring (DVD)Replies: 5Last Post: 17th Sep 2007, 18:53
