  1. I got a problem with the return button. I set the return button on all sub menus to take you to the previous menu, but since there is no menu prior to the main menu, the button is disengaged. However when you push return on the main menu it takes you to the commentary On/Off menu. It does not do this in the simulation, but does it in all the DVDs Ive burned and on a few different players I tested it on.
    I've checked all connections and all is good. I only have this problem on this one DVD, which is the only one I made with scrips pertaining to the commentary on/off. I'm wondering if the script has anything to do with it.
    -Thanks
    Nov 2003
    New New York, Year 3000
    Try making the button return you to the same menu you are on. It might cause the menu to be reloaded, but it should stop it from doing anything stupid.
    I'd make the return button toggle between main menu and the main feature, personally.
    If it isn't broken, take it apart and find out why.
    blog: deadsierra
