I have a Hi-8mm tape and believe my friend has a 8mm camcorder.
One of his 8mm tapes looks to be the same size as my Hi-8mm tape...
....can I play my Hi-8mm tape in his 8mm camcorder?
Thanks,
Will Hay
tgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
no
Hi8 is a higher resolution, higher bandwidth video format than standard 8mm (just like S-VHS vs. standard VHS). A Hi8 machine can play back an 8mm tape, but an 8mm machine cannot play back a Hi8 tape.
many Hi-8 cams will play regular-8 tapes, but not the reverse.
- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
Actually these days the 8mm and Hi8 tapes seem to be *exactly* the same. I have bought 8mm tapes, drilled the extra hole in the casing which switches on Hi8 and recorded on them in a Hi8 camcorder. The results are identical to the much more expensive Hi8 tape.
Originally Posted by rgs_uk
DAT and exabyte tapes are also the same though ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
okay, thanks.
I have about 60 Hi8 and regular 8mm camcorder tapes that I can't get toplay
By Chris McDowell in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 7th Jun 2010, 18:12 -
Convert PAL 8mm tape (Hi8, Video8, Digital8) to NTSC DVD
By scotty123 in forum Video ConversionReplies: 0Last Post: 9th Oct 2009, 12:49 -
By scotty123 in forum Newbie / General discussionsReplies: 3Last Post: 3rd Oct 2009, 00:34 -
Will a Digital 8 camcorder read 8mm tape?
By Tenacguy in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 10th Jun 2009, 13:24 -
8mm camcorder tape playback suggestions?
By Bix in forum RestorationReplies: 8Last Post: 23rd Aug 2008, 01:02
