I don't see how since you're not adding anything to the disc that could make it imbalanced.Originally Posted by SilverBlade
Results 31 to 45 of 45
That would be one of the pluses. Simply its part of the disk and not an add on.
I would see this thing being useful (for me at least) making audio CD"s and DVD's. But since I'll be soon getting an mp3 player, I'll have no use for the Audio CD"s, and for the DVD"s, I only trust Maxell, and they so far haven't acquired a license for lightscribe. If they don't, then this will be useless to me. The technology looks promising, but if its on crappy media, all bets are off for me
who maxell has the best media ? they are not to consistent in their suppliers either ..
I have yet to find a Maxell DVD-R or DVD+R, only Maxell DVD-RAMs.
"It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..." -
I'm curious - how long does it take to lightscribe a disk? I've heard it takes about 40 minutes to do one. Depending on complexity of content of course.
Thanks ~ John -
geez -- that is freaking long , if true ...
i doubt anyone would wait that long ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
With a waiting time like that, I think I will just stick with a permanent marker.
If its 40 minutes..... Then its dead in the water.
Had some customer report they thing the write time on a R200 to print a disk is way too long.
Are you sure its 40? Would figure the speed is about the same as writing the data side. Or could it be they need to "step" it manualy instead of reading the track. -
they say only a few minutes at most ..
A few minutes at most sounds good. Now, the only problem is to get other companies behind it. That label really looks quite exquisite.
Perhaps this technology could also get modern printers beyond the bubblejet, too. Here's to hoping."It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..." -
There are lazer color printers, which print like a photo, but they are crazy expensive still. A couple thousand
color laser printer cost as little as $340 ...
and go up from there
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=544781&CatId=245
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=929544&CatId=245
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=245"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Don't know about pricing on the drives themselves, but HP is already selling new PCs with Dual Layer Lightscribe drives installed for as low as $399; not a bad deal if it's time for a new one.
EDIT: (Just saw BJ_M's link, guess I should have read all the way through again.)
If you can catch them in store today (I believe it's the last day). Staples has the Konica / Minolta 2300DL for $300 in store, no rebates. It's no longer listed on their site, although there are some newer models available for sale on their site now.Nothing can stop me now, 'cause I don't care anymore.
Suggestions for a new SATA DVD Drive with Lightscribe....
By mjvgiese in forum DVD & Blu-ray WritersReplies: 4Last Post: 22nd Sep 2009, 02:44 -
dvd reading lightscribe disc only
By jonij in forum Newbie / General discussionsReplies: 2Last Post: 14th Dec 2008, 15:12 -
lightscribe drive question HP Pavilion DV6000Z
By cduval04 in forum DVD & Blu-ray WritersReplies: 1Last Post: 11th May 2008, 04:15 -
sw can not see lightscribe drive, but CD/DVD burner works...
By jwjr417 in forum DVD & Blu-ray WritersReplies: 23Last Post: 7th Mar 2008, 17:03 -
Free soft for burning DVD LightScribe Disc
By fjmr in forum MediaReplies: 4Last Post: 1st Dec 2007, 22:01
