Is there a program that converts srt files to sub files because sizzle won't accept srt files
Results 1 to 11 of 11
"Good Luck 007"
In Memory of Desmond Llewelyn -
What is sizzle's ripper?
There is a windows tool called "SubCreator" which can convert subtitles between various formats....You can use it under VirtualPC...
I had to redownload this to see what you meanOriginally Posted by qshartle
A subtitle ripper, I geddit now. Momentary confusion with a DVD ripper there
Opps
, shoulda specified that.
Cheers
Q"Good Luck 007"
Inside the sizzle 0.1 dmg is the sizzle app, 2 textfiles, and another app called subtractor.
How to demux .srt from mkv, then convert .srt to .smi and mux .smi to mkv??
By narayanan in forum SubtitleReplies: 1Last Post: 7th Aug 2010, 23:49 -
Subtitles Tools (SUB to SRT 1.33) for OCR Chinese Txt to SRT
By dennis3377 in forum SubtitleReplies: 0Last Post: 10th Dec 2009, 01:46 -
SRT SUB
By sg999 in forum SubtitleReplies: 13Last Post: 2nd May 2009, 23:27 -
Working with .sup and .srt
By ma2kp in forum SubtitleReplies: 2Last Post: 8th Dec 2008, 22:34 -
.sub to.srt?
By Hank Kinsley in forum SubtitleReplies: 9Last Post: 14th Aug 2007, 13:25
