I was wondering if anyone has success recording widescreen video using the JVC M10 and maintaing the widescreen format?
I was attempting to record a 16:9 video clip I made using my camcorder to the JVC M10 using the s-video hookup to a dvd-rw, what I got was regular TV format (full screen) with black bars on the top and bottom.
Also the widescreen video I capture from Direct TV also shows in full screen mode only. I thought that the recorder was able to keep the original format of the video.
I must admit I haven't really researched this subject, yet I would like to know if someone has done it successfully and how were you able to do so.
Thanks to any advice given.![]()
Results 1 to 9 of 9
Do unto others....with a vengeance!
You might try a RAM. The Panasonic manual says that with DVD-R it will be fullscreen regardless of input format, it doesn't say anything about RAM recording fullscreen.
I think if you use the firewire input instead, the 16:9 flag from the digital camcorder footage is included in the stream to the DVD recorder and should work. If you would rather transfer over the analog input (to color correct, etc.), you can always rip the resulting MPG from your recorded DVD-RW and add the 16:9 flag with Restream, then author the final DVD on your computer.
samijubal,
RAM has nothing to do with aspect ratio.
ejai,
First of all, you need to go to set up to:
Function set up
Video In/Out
Monitor Type
and set your monitor type to 16:9 fixed.
I captured footage from Sony D8 camcorder recorded in 16:9 mode via FireWire and JVC played it back perfectly. I am not sure about S-Video -
I will look into this as well, thanks.Originally Posted by kabaneroDo unto others....with a vengeance!
Will changing the monitor option of how you see the video also change the way it is recorded? I thought this option was just to correctly set your type of monitor that you were watching so that the aspect ratio would be correctly displayed.
I know some cameras don't support true widescreen format. I don't know much about JVC but I know Canon's Elura models do, as they use the full width of the CCD.
JVC DR-M10 Loading and Repair Question
By usaf64 in forum DVD & Blu-ray RecordersReplies: 555Last Post: 1st Jul 2013, 12:33 -
HOT DEAL: St. Louis Craigslist - $75 JVC DR-M10 DVD Recorder
By jbd5010 in forum Off topicReplies: 2Last Post: 16th Mar 2011, 09:21 -
problem recording with jvc dr-m10
By restauroman in forum RestorationReplies: 3Last Post: 28th Feb 2010, 12:47 -
JVC DR-M10 help
By colt4523 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 20th Mar 2008, 07:53 -
How do JVC combo VHS/DVD recorders compare to M10 or M100?
By DGinnetty in forum DVD & Blu-ray RecordersReplies: 7Last Post: 27th Sep 2007, 13:14
