Like the subject says guys .... how is this done ........
BTW, Is anyone alse like me, and CCE will ONLY work if the audio processing is unchecked???????? (ie Video only)
If you have an Athlon CPU, yes you have to uncheck audio, otherwise cce wont work.
There are several ways to frameserve to cce sp 2.5.
1] Avisynth and its mpeg2dec plugin. MPEG2DEC reads the .d2v serves directly to cce.
2] VFAPI and VirtualDub. Convert .d2v with VFAPI and open the fake avi in Vdub>frameserve to cce.
3] If you dont need any filters, just convert the .d2v with VFAPI and open it in cce.
4] If you have cce 2.6 or any problems with method 1 or 2, open the .d2v in TMPG, add filters, save project. Convert the project with VFAPI and open it in cce.
5] you can mix these methods as you like. TMPG accept .avs as well as .vdr. VirtualDub accept .avs. You can open a .vfapi.avi in Avisynth and VFAPI 1.03 converts .avs to .vfapi.avi.
This is my favorite method: http://www.doom9.org/mpg/d2a-mpeg2dec.htm
Actually for CCE you should always uncheck audio, it doesn't do it well at the best of times, use tooLame or SCMPX.
New to HC Encoder: .D2V files as input?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 27th Oct 2011, 09:41 -
Is there a way to map the largest files on a dirve visually?
By yoda313 in forum ComputerReplies: 12Last Post: 17th May 2010, 13:43 -
Will Windows Media Player Serve MP4 files
By SCDVD in forum Newbie / General discussionsReplies: 6Last Post: 6th May 2008, 12:44 -
Map & Evo files?
By murof in forum Newbie / General discussionsReplies: 1Last Post: 31st Mar 2008, 11:14 -
meGUI .VOB to .D2V Conversion - Audio Demuxing Speed?
By quicksilverg4 in forum DVD RippingReplies: 0Last Post: 29th Dec 2007, 17:04
