So the situation is, I have my project authored (as both the dvd folders and an iso image), the dvd folder plays just fine on my computer, but once burned, some of the clips skip. So far I have tried around 5 or 6 different DVD-R's, most of them just wouldnt play, some did but skipped, and then finally the discs I have now (Bulkpaq printable 4x Speed) which I got the video onto (just the main video for the premiere of it this friday) played fine, so I ordered 150 more yesterday.
Then I authored the final DVD (Ulead DVD Workshop) with the main video and some DVD extras. When I burned this (from the folders) one of the DVD extras skipped in my Playstation 2, and in my P.C, none of them played. I then tried to burn from the iso image, and the extras played, but still skipped. I tried burning it on my DVD+RW and it seemed to play fine, for some reason everything I've ever burnt onto this DVD+RW worked perfectly. So what can this be?! I would guess it's media, but surely 6 out 6 disk brands I've tried can't be faulty, and thinking if it's the burner (Liteon 4x DVD+/-RW) I have never burnt a faulty CD on it. But I can't think of many occasions where I've burnt a perfect DVD on it. Any help will be greatly appreciated, thanks.
EDIT:
Burning with Nero.
It looks to me as if your DVD player/playstation don't like DVDr's! Playstations, except for the latest, are notoriously picky about media, many older DVD players will only play +r and not -r and vice versa. I used to own an oldish samsung player that would sometimes play a disk falwlessly. Next time, same disk, it would stutter and freeze.Originally Posted by matthirst
Try a different player. -
Which burner are you using ? WHich brands of disk have you tried to use ?
Not bothered by small problems...
Spend a night alone with a mosquito
Windows 7 DVD maker won't work
By 81artmonk in forum Software PlayingReplies: 7Last Post: 14th Aug 2010, 10:18 -
How do you play a rental DVD on a pc? It won't work for me!
By candacec in forum Software PlayingReplies: 7Last Post: 22nd Jul 2010, 00:11 -
so many hours and than it donīt wonīt to work. DVD Slideshow GUI problem
By d.enz in forum Newbie / General discussionsReplies: 10Last Post: 5th Mar 2009, 13:49 -
Free DVD encrypter for copying DVD's? DVD43 won't work for me
By marcias_70 in forum DVD RippingReplies: 1Last Post: 2nd Feb 2009, 04:09 -
Help with converting BBC HD Stream to DVD (Normal methods won't work)
By Killer3737 in forum DVB / IPTVReplies: 3Last Post: 30th Jul 2007, 10:23
