    Las Vegas
    Did anyone run into this problem. I use DVDDecrypter to rip the Vob files from the Star Wars EP1 DVD. All the Vob files were copied to my hard drive and all the files converted fine to SVD format, "EXCEPT" the very first VOB file, this is the file that has the first 10-plus minutes of the movie. I played this VOB file and found out that it is jumping back & forth between English and other languages (Spanish I think). TMpegEnc keeps give me error msg when I tried to convert this poriton to mpeg. Anyone out there has any solution to this. It bugs me that I can convert the rest of the movie to mpeg, except the beginning.
  2. Episode 1 is multiangle, you need to use smartripper in it's movie mode to get it done right (this is because of the scrolling intro text, which is in different languages).
  3. hi man !
    i had that problem ....
    encode the program using the DVDDECRYPT and than use FLASK V2 0594
    at
    http://www.geocities.com/installflaskmpeg0594/
    and it will work fine . !!!!!
  4. use SmartRipper and select one angle and put your key check as once and rip it and that will do the trick
    Las Vegas
    Thanks guys. I used smartripper as you suggested, and it worked.
  6. DVDdecryptor can take care of multiangles too...in its options, you can check "process multiangles" and it works really well....(try using smartripper to rip T2 ultimate edition)
