  1. I've downloaded Subrip from various different sites. I install it and everything seems to have gone well,but the minute I attempt to open the program it crashes.
    Im running a 3.2 P4, 1GB ram, and Windows XP
    Why wont this simple program work properly?!?!?!?
    Im pulling my hair out. Please Im desperate.
    Look, let me explain something. I'm not Mr. Lebowski; you're Mr. Lebowski. I'm the Dude. So that's what you call me. That, or Duder. His Dudeness. Or El Duderino, if, you know, you're not into the whole brevity thing--
  2. From my experience it doesn't like to run alongside other apps which access your dvd drive. Try closing Decrypter and any programs like it and then giving Subrip a try. You may have to launch it 3 or four times before it works.
    HTH
    -freestyler
  3. right click the application's icon, choose properties, compatibility and check run this program in compatibility mode for windows xp/me
