I'm working on converting my old video tapes to DVD's, but i'm doing it the longer way of encoding to uncompressed AVI, and then creating dvd compliant mpg's, and then creating my own custome menu's, etc.
For the menu's I'm learning/using Adobe Encore DVD.
For conversion of the AVI's I WAS using TMPGEnc Plus, but - I don't know if I'm totally happy with the quality of the final product. There seems to be some static-like artifacts appearing around contrasting, edges, etc. Am I going to get this no matter what? Or is it a flaw in TMPGenc and are there better tools to convert? I'd like to create videos that are as close to the original VHS, and as close to the quality of the uncompressed AVI as possible.
Thanks for any tips and help.
That may be over scan. and it wont show up on your DVD when you watch it on TV.
Just a guess.. -
No, unfortunately. It's more or less stuff I've noticed when watching it on tv. I may just be completely over-anal and too much of a perfectionist and expecting something more than what is capable of happening.
I have a canopus advc-100, and have been using DVIO (successfully with no frame drops, or audio-sync problems). The original AVI still looks great - like a carbon copy of the vhs tape (albeit, i'd love to clean it up a bit.) It's in the encoding down to a dvd-compliant file that the artifacts appear. I've also tried using nero's dvd-encoding (directly from the AVI) but that looked even worse.
Ok, Cool. I use the sameOriginally Posted by MikeMGMVE
I actually think your problem may be incorrect field order - I went through that when I started converting VHS and TV. In still sections everything's fine, but as soon as someone or something moves, it's like they have about 4 outlines ???
BTW, I'd recommend reading This guide by FulciLives, as it incorporates editing and noise removal - a must for VHS and TV caps IMO.If in doubt, Google it. -
well it's not necessarily lines, but just static bits around the edges of whats moving on the screen. it's tough, cos it's a concert, so, it bugs me. thanks for the guide! i shall read
DVD conversion questions
By Stickboy42 in forum Video ConversionReplies: 3Last Post: 11th Dec 2011, 00:10 -
Final Cut Pro 5/File quality and conversion questions to .avi
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 0Last Post: 9th Feb 2010, 20:24 -
AVI to DVD Questions
By RdM642 in forum Video ConversionReplies: 2Last Post: 6th Feb 2010, 21:30 -
VOB file conversion to AVI...many questions
By tonyclem in forum DVD RippingReplies: 19Last Post: 7th May 2008, 10:39 -
Playback hardware and other questions for VHS to DVD conversion
By maeks84 in forum Capturing and VCRReplies: 0Last Post: 23rd Aug 2007, 12:02
