    Jan 2004
    kansas
    My wife will get me a R200 for Xmas but I'm not that experienced messing around with printer software, with help from this forum will I be able to set this up so I can use this strictly for printing on cd and dvds? I already have some Prodisc (for hub printable) and Ty Yuden (for non hub printable) so I would just need step by step instructions on how to get started.
    Also are the replacement ink cartridges sold by Rima ($6 each) and the cartridges sold by Megatoners both acceptable for a cheaper ink alternative?
    Thanks!
  2. Member hiptune's Avatar
    May 2003
    Los Angeles, California
    First get you some really good pictures save to your desktop. Tweak them to pure perfection, and save the graphics in bit maps, say 5 inches square.
    The more important part is the good pictures. The r200 part is very very easy.
    Remember that bit maps are better quality than jpegs. So stick with them when you have a choice.
