I have some problems with decoding realvideo files with the new (0.0.9q) version. The files are identified as
VIDEO: RealVideo, size: 320x240, 15.000 fps. AUDIO: racookmac, 44100Hz, 44 kbps.
by ffmpegx and t I have attempted to encode them to XVID (mencoder). The process fails with the following error message:
Any ideas? Furthermore, I had the "encode audio" option unchecked, and had a look at the command sent to mencoder. I saw the option " -oac copy" as given. Shouldn't it be "-nosound" instead?Encoding started on Tue Nov 30 00:09:22 CET 2004
MEncoder dev-CVS-041116-19:27-3.3 (C) 2000-2004 MPlayer Team
AltiVec not found
CPU: PowerPC
Reading /usr/local/etc/mplayer/codecs.conf: Using built-in default codecs.conf.
success: format: 0 data: 0x0 - 0x3a5efd6
Font /usr/local/share/mplayer/font/font.desc loaded successfully! (206 chars)
REAL file format detected.
Something went wrong, no index chunk found on given address (61133448)
======= WAVE Format =======
Format Tag: 28515 (0x6F63)
Channels: 2
Samplerate: 44100
avg byte/sec: 44100
Block align: 640
bits/sample: 16
cbSize: 26
Unknown extra header dump: [0] [80] [0] [10] [0] [16] [2] [80] [0] [10] [1] [0] [0] [3] [8] [0] [0] [20] [0] [0] [0] [0] [0] [5] [0] [5]
VIDEO: 03VR [30202002,010A9030] 320x240 (aspect 0.00) 15.00 fps
VIDEO: [03VR] 320x240 24bpp 15.000 fps 0.0 kbps ( 0.0 kbyte/s)
Error: dlcompat: file "/Library/Application Support/ffmpegX/reallib/drv3.so.6.0" not found
ERROR: Could not open required DirectShow codec drv3.so.6.0.
ERROR: Could not open required DirectShow codec drv33260.dll.
audiocodec: framecopy (format=6f63 chans=2 rate=44100 bits=16 bps=44100 sample-640)
Writing AVI header...
0 ftime:=0.0667
xvid: using library version 1.1.-127 (build xvid-1.1-cvshead)
Opening video filter: [expand osd=1]
Expand: -1 x -1, -1 ; -1 (-1=autodetect) osd: 1
Opening video filter: [scale w=320 h=240]
Opening video decoder: [realvid] RealVideo decoder
opening shared obj '/Library/Application Support/ffmpegX/reallib/drv3.so.6.0'
Read the RealVideo section of the DOCS!
VDecoder init failed
opening shared obj '/Library/Application Support/ffmpegX/reallib/drvc.bundle/Contents/MacOS/drvc'
Selected video codec: [rv30mac] vfm:realvid (Mac OS X RealPlayer 9 RV30 decoder)
ODML: Aspect information not (yet?) available or unspecified, not writing vprp header.
VDec: vo config request - 320 x 240 (preferred csp: Planar I420)
VDec: using Planar I420 as output csp (no 0)
Movie-Aspect is 1.33:1 - prescaling to correct movie aspect.
SwScaler: using unscaled Planar YV12 -> Planar YV12 special converter
videocodec: XviD (320x240 fourcc=44495658 [DIVX])
xvid: par=0/0 (vga11), displayed=320x240, sampled=320x240
xvid: CBR Rate Control -- bitrate=4000kbit/s
Many thanks for your help!
I forgot to mention that the version 0.0.9p registers the video correctly as
and encoding seems to work.VIDEO: RealVideo, size: 320x240, 15.000 fps. AUDIO: RealAudio, 44100Hz, 44 kbps.
Not able to encode realvideo with ffmpegX on MacOS SnowLeopard
By oicram in forum ffmpegX general discussionReplies: 2Last Post: 10th May 2011, 15:55 -
What tool is idea to convert the RealVideo VBR into the DVD?
By coody in forum DVD RippingReplies: 1Last Post: 23rd Aug 2008, 11:16 -
RealVideo Source to MPEG2, problems.
By mattstan in forum Video ConversionReplies: 5Last Post: 4th Aug 2008, 06:06 -
converting RealVideo 10 to avi
By user543 in forum ffmpegX general discussionReplies: 2Last Post: 30th Oct 2007, 03:06
