Hi every one I need some easy software to burn a 900.mg avi movie on a dvd so I can play it on my home dvd player not my computer help me out guys THANKS![]()
Results 1 to 9 of 9
#3 lives on
Click on CONVERT and then Newbie All-in-one guides in the top secret menu here to the left.
Thanks baldrick i have did that but im dong something wrong i used Cususoft AVI to VCD / DVD i pick avi to dvd i was able to burn it on a dvd but it will still not play on my home dvd player i have a 62'' tv that i want to watch some of these avi's on... im not sure what's up with that it will not beat me it my cost me some dvd's but i will get some thing to work thanks
#3 lives on -
By using WinAvi video converter I convert my Avi movie to DVD then I burn it by many softwares like CloneDVD and Nero but is not working on my home DVD player...What the solution?
If I was a snide bastard, I suggest you buy the original, however that may be unfair.
What is your player (make/model) ?
What format of DVD did you burn to ?
What burning program did you use ?
Did you burn it as a DVD Video, or simply DVD ?
What do you have on your HDD before you burn ?Read my blog here.
The solution is to read and try all of the AVI to DVD guides you can find.
/Mats -
HI,
the process when you burn the mpeg files directly to dvd unclear !
usually, what i do is to use nero ultra edition and chose
" make my own dvd" option
there you can import your mpeg2 files...make chapters etc...then burn onto dvd. -
use virtualdub to demux,and then tmpegEnc to convert to mpeg1 or mpeg2;it takes longer but the quality is good.
a lot standalone players can play divx,philips642,xoro,kiss,if you have such a player you can burn them directly to your cd or dvd.i love this site,it's my favorit. -
Hi Basspro and rock2004,
Easy software to do the newbie job (AVI to DVD) would be Nero Vision Express.
Open the program, chose Make DVD, after that click Add Video files, add your AVI and click few "Nexts".
I've never had a coaster, the quality is the same as AVI source and the resulting DVD's play in standalones.
Avi Movie files shut off towards the end on Home DVD player.
By mrxny in forum Newbie / General discussionsReplies: 2Last Post: 11th Oct 2011, 00:24 -
Is it possible to watch your home movies via internet anywhere you go?
By pwangdel in forum Video Streaming DownloadingReplies: 9Last Post: 1st May 2011, 03:17 -
MKV files and i want to convert to avi to watch on my DVD player
By vampypiano in forum Newbie / General discussionsReplies: 9Last Post: 7th Nov 2010, 07:59 -
How to watch a .avi file in a dvd player that support divx format?
By albi123 in forum MacReplies: 5Last Post: 18th Feb 2010, 09:53 -
Newbie: need basic explanations: From AVI to home dvd player
By Raoul777 in forum Newbie / General discussionsReplies: 3Last Post: 21st Aug 2007, 23:13
