how to delete ur older posts
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator BJ_M
Closed Thread
What are you trying to achieve?
/Mats
i want to add a flash window while window media player is playing movie....it is just like a flash ticker.so that i can add important news on through flash or ads through flash....but the question is to the flash player window must be always on top of window media player while it is in full screen mode....it is confusing butt imagine we can play boht if flash file size is smaller (60 *240)
Is it for some "kiosk" application? (I don't see a solution for this actually, just curious!)
/Mats
I used to do this myself, here is the basic overview as to how to do it...
I created my Flash movie and exported it as an avi file, I then imported it into Premiere and added another video layer, I used an alpha mask because the main movie was in the background, the animated logo was a 3dish type of flash movie with a blue background, the blue background would make it easy to take out later in the main movie. And yes, Flash MX will export an avi file. It has been sometime since I have done that. I hope that helps you a little, if you are looking for a one shot software solution, you are out of luck.
As far as adding a cgi flash backend to a movie window, hmm, don't know if that is even possible, unless you imported your movie into flash, yes you can do that too, your system better be powerful though. Then you can do scripting (actionscript) and run a cgi script to give the ticker information from a text file. I actually learned this in Masters Of Flash MX. However I did not import a movie, rather loaded a movie from a remote source into the Flash window. lol.. you are gonna have to do some serious research to make this happen. I am tooooo lazy to do it for you.
New posts
By samijubal in forum FeedbackReplies: 2Last Post: 31st Jan 2010, 12:21 -
"reported post" notification is showing up with the latest posts
By aedipuss in forum FeedbackReplies: 1Last Post: 26th Jan 2010, 18:49 -
Question how to delete files that won't delete
By jimdagys in forum ComputerReplies: 18Last Post: 9th Sep 2009, 13:09 -
First posts to end all first posts
By zoobie in forum Off topicReplies: 4Last Post: 24th Apr 2009, 12:54
