Hi,
I'm from the UK,so the DVD format is PAL.
When ripping a music DVD which is NTSC do I have to adjust any settings on DVD Decrypter or does it automatically save it as NTSC.
Another thing is when copying up to DVDR and the files are NTSC do I need to alter NERO settings to make sure the copy is a true NTSC copy.
I'm a little confused at making sure a NTSC original stays NTSC on the rip and copy.
Thanks,
Ian
DVD Decryper does not care about format, neither does nero. Both treat DVD as files and data. BTW, you can burn with DVD Decrypter instead of Nero. Sometimes it is easier (especially if copying a single layer disk) to go ISO Read/ISO Write in Dycrypter.
Read my blog here.
The programs care little about PAL/NTSC. What you rip is what you burn, unless you purposely go and change it.
Exception to the rule is when using Nero's "build a DVD" wizard thing, which will nudge you if you are using source material that isn't in the same format as your current region... and then give you the choice of changing the format if you like.
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
DVD Decrypter - Time based settings?
By badboytim999 in forum DVD RippingReplies: 6Last Post: 11th Nov 2010, 16:17 -
Question about PAL & NTSC ripping and re-authoring
By Jack_Dante in forum DVD RippingReplies: 6Last Post: 23rd Mar 2010, 14:39 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 22:43
