Hi all,
I couldn't find an answer to this on the search or through browsing so would like to run something by you.
I'm using SVCD2DVD v1.51.2.0 and consitantly get the same results no matter what I convert or what media I use...
After about 15-20 mins of playback the video starts to go all jerky like it's dropping frames or something. The sound is fine and after another 10-15 minutes it's all fine again. I could undertand if it were on the odd bad original source or cheap media but it is consistant throughout and on different playback devices as well![]()
Using AMD AthlonXP 3200+ with 1GB Corsair Ram - all processes nice and smoothly in the conversion.
Does anybody have any suggestions?
Results 1 to 13 of 13
Is this on your DVD player? What is it like on your PC?
does it play fine on the computer..... if it does, then its your dvd player..
ps2 dvd players aren't that great, also make sure you don't do anything else while your encoding...
but try the new version 2 with DVD DEcRYPTER option ...... that works for me... nicely..
blayze -
i imagine ur using cheep media by the sound of ur problems,i always use ritek g04-g05 dye/discs and have no problems,if any problems were to arise i would burn at a slower speed.also have u mounted ur vob/image etc in daemon to test first ?.
erm..also that dvd playewr u paid loads for a year or more ago is probably not very good at reading copies,get a newer/cheapo quonfontonwango dv player (19£) from lidl's,they play anything and everything
Email me to cancel the registration and issue a refund.Originally Posted by bloke2SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Personally I think this is great software and worth every penney. Even though the best things in life are free, there are a few exceptions to the rule. I cant imagine that anyone could make a mint out software anyway.
Originally Posted by ChrissyBoy
not neccessary mate, i was just blowing off some steam. didn't mean to cause offence.
For what it's worth I use Ritek G04/G05 and Fuji03 as well as Verbatim DVD+RW and am still getting same results. Tried burning on Pioneer 104 and NEC 2510a. I've tried all suggestions inluding the new betas and still get the same. Various sources which are all good and I've even tried it on a completely different configuration of mobo and HDs.
Oh well, just wasn't meant to be for me I guess. Not worth losing sleep over
Cheers -
Yep, I'm having the same problems, only on divx -> dvd conversion...
- knewknow -
Ok. If you have a example, please upload it to ftp://BetaTester:b%40dger@ftp.svcd2dvdmpg.com:7676/Jerky
Include a text file detailing the issue (time of jerkyness, DVD player used, software player used) and i will investigate.
ThanksSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Jerky Video.
By wasimismail in forum Video ConversionReplies: 27Last Post: 15th Dec 2009, 12:35 -
Audio and video off if captured longer then 10 mins?
By Ghtpua in forum Capturing and VCRReplies: 4Last Post: 7th May 2008, 12:39 -
video still jerky
By milway in forum Video ConversionReplies: 15Last Post: 3rd May 2008, 17:01 -
Video is jerky
By arnie22112000 in forum Newbie / General discussionsReplies: 5Last Post: 22nd Apr 2008, 01:49 -
How to burn a 157 mins. video on a 120 mins. dvd
By Gerald Sr. in forum Authoring (DVD)Replies: 2Last Post: 20th Jan 2008, 03:19
