It' either me, or my software, or my glasses!
I am following the procedure described in "FOOLPROOF AVI,DivX to SVCD using CCE" www.vcdhelp.com/avitovcdfoolproofusingcce/ .
Everything works OK until I reach Pt. 7 (pg. 3/11).
It says: "...right click on CCE and then press ADD and go to your directory...". What "ADD" are we talking about?!
I cannot see this option!
My CCE is the Lite version, 2.62.01.00.
The Virtualdub I am using is 1.4.7.
I cannot go past this step. Is anyone brave enough to tell me the truth? I'll try to handle it...
What do I need to do to be able to continue?
Thanks!
This guide uses cce sp 2.5 or 2.25, nothing else. CCE 2.6 lite or sp does dot accept .vdr signpost files.
Thanks Truman!
At least I can keep my glasses now...
My intention was to create an SVCD from a movie that I have in DivX format.
I am wondering if the CCE Light that I bought could be of any use for this purpose?
Thanks! -
CCE lite encodes avi/ mov files to MPEG-1/2 in CBR mode. Just drag a avi file into the small window, that pop up, when you start it. After that the configuration dialog will start. I can not help you much with this version.
Avi files missing header?
By hockeygt975 in forum Newbie / General discussionsReplies: 4Last Post: 2nd Nov 2014, 04:18 -
AVI jerky/missing frames?
By MdMa11 in forum Video ConversionReplies: 10Last Post: 26th Apr 2010, 00:13 -
Am I missing something here? - DVD to resized, interlaced DivX
By wiseant in forum Video ConversionReplies: 8Last Post: 29th Aug 2008, 12:43 -
CCE VS DivX
By SteveF22 in forum Authoring (DVD)Replies: 9Last Post: 25th Aug 2007, 21:13 -
What am I missing (DVD to Divx)
By suppafreak in forum DVD RippingReplies: 10Last Post: 28th Jun 2007, 17:30
