  1. Can it be done? I think not, but I've been thinking if I jump to the end of a title which has a post command to go to the menu, that'll do the same thing.
    Dave
  2. Free Flying Soul liquid217's Avatar
    Feb 2002
    if it is in the same titleset, simply use 'call menu 1', or 'call menu 2'. If the menu is not in the same titleset, you will need to go through the VMGM
  3. It's in the same titleset.
    If I do what you suggested, it says "cannot 'call' a menu from another menu. Use 'jump' instead".
    If I do "jump menu 1", nothing happens when I select the hotspot on the second menu. If I do "jump menu" it says ERR: cannot find PGC with entry.
    Here's some XML if it helps. I've got one menu that plays one of two titles. Each title goes to a second menu with a post command (implemented via a register). The second menu has a single button that goes back to the first menu (or at least is supposed to).
    <dvdauthor dest="c:\crap">
    <vmgm>
    </vmgm>
    <titleset>
    <menus>
    <pgc>
    <pre>
    if (g1==2) jump menu 2;
    </pre>
    <button>jump title 1;</button>
    <button>jump title 2;</button>
    <vob file="c:\crap\Menu1_sub.mpg"/>
    </pgc>
    <pgc>
    <button>jump menu 1;</button>
    <vob file="c:\crap\Menu2_sub.mpg"/>
    </pgc>
    </menus>
    <titles>
    <video format="pal" />
    <pgc>
    <vob file="c:\crap\Title1.mpg"/>
    <post>g1=2; call menu;</post>
    </pgc>
    <pgc>
    <vob file="c:\crap\Title2.mpg"/>
    </pgc>
    </titles>
    </titleset>
    </dvdauthor>
  4. Doh!
    "jump menu 1" does work, it's just thanks to my pre logic it jumped straight back to menu 2. Needed to set g1=1 before the jump.
    Oh I'm so stupid.
  5. Free Flying Soul liquid217's Avatar
    Feb 2002
    Ahh, I haven't had my morning coffee yet. I really did mean 'jump menu 1' and 'jump menu 2' above
    I see your problem here in this example though. In your menu 2, you need to set the register as well, else it will go BACK to the menu2.
    edit: Nevermind, you saw it before I did.
  6. Great minds...
    Thanks for your help. Works perfectly now.
    Dave
