What is the best type of DVD-R (4X, 8X) media is best to use with the R200?
I have an Epson 900, I use only Prodisc Media. I get mine from either www.supermediastore.com and www.rima.com. They have both the 4X and 8X media.I would suggest getting a sample pack to see if you like it.
Link for images of printed media with the Epson 200:
https://www.videohelp.com/forum/viewtopic.php?t=245175 -
The Epson R200 is a printer not a burner. It doesn't matter whether you use -R or +R.Originally Posted by lifesajrny
Thanks JYN999, I know it's not a burner. I prefer to use DVD-R media.
Any so long as its INKJET Printable.....
Used Riteks, Datawrite. All look great.Not bothered by small problems...
Spend a night alone with a mosquito -
In the past, I have been using white generic printable DVDs, and they work well.Originally Posted by lifesajrny
Just picked up Ridata white printable, and they work as well.
Also picked up silver Prodata printable, and they work very well, but look a lot different. Not just because they are silver, but because you seem to be printing onto a transparent layer. If you don't look directly at the surface, you see a reflection of the text on a lower layer - gives it depth.
Unless you are looking directly at the surface, it makes it a little harder to read until you get used to it.
However, I like it..... -
I have used Ritek G05, Prodisc, Optodisc and Bealls to print on and all are very nice. Mostly hub printables.
Some printable discs have a slightly rough or textured surface and dont print as nice in my honest opinion. The smooth tops take the ink nicely and are dry to the touch upon exiting the printer.
Epson R200, new cheaper disk printer?
By The village idiot in forum MediaReplies: 309Last Post: 26th Mar 2012, 09:56 -
Win7 drivers for the Epson R200?
By MrSpeed in forum MediaReplies: 0Last Post: 27th Apr 2010, 04:50 -
Epson R200 printer and DVD art
By dymx in forum ComputerReplies: 4Last Post: 8th Jul 2008, 11:57 -
Growing very tired of Epson's R200 - R220
By stiltman in forum MediaReplies: 25Last Post: 25th Jun 2008, 23:58 -
Installed R260 Epson, and the print CD keeps recognizing my old R200
By faramith in forum MediaReplies: 11Last Post: 2nd Dec 2007, 18:29
