  1. I have a video clip converted to a Quicktime movie. I want put it on a DVD. When I try to burn it with Toast 6 it indicates the length is 1:56:31 long. But when I try to burn it on a standard DVD disk it says I need 5GB of space. Why won't fit since it's less than the 2 hour limit of the disk and how can I remedy this problem?
    Jun 2001
    Silver Spring, MD USA
    You're probably using PCM audio. If you have Jam installed, Toast 6 should offer to convert your PCM audio to AC3.
    Oct 2003
    Canada
    Choose save as image, then run the resulting video_ts folder through popcorn, dtox or dvd remaster.
  4. Member decay's Avatar
    May 2004
    how much free space do you have on your scratch drive?
    you might have less than 5 GB.
    dk
  5. Thanks for the tips. By changing the audio to AC3, I was able to fit the video clip on one DVD
