I have a problem with converting an svcd to dvd ,the output crashes after a few minutes encoding in main concept and the patrtial mpeg file has glitches that arent in the oringinal source, canopus procoder wont start encoding with the file but the source file looks and plays perfectly i have the latest ffdshow filter installed and the klite codec pack,also powerdvd6 is installed any ideas would be very much aprecciated![]()
Why convert at all? If your goal is to put it on DVD, use svcd2dvdmpeg - no reencoding needed! Saves you time and quality. And while I'm at it: ffdshow - good
, codec packs - evil
/Mats -
It's fairly compliant, even if it's out of specs in respect to the DVD standard. Try and see.
Not sure about this, but i think the AR will carry over to the DVD - it's still mpeg2, right?
As VCD video is valid as DVD video too, (and TDA converts the audio to be DVD compliant) I can't see why a player shouldn't play it - maybe it doesn't fully support the DVD standard, or something else is awry?
/Mats -
Just tried Svcd2dvdmpg and it defaults the AR to 4:3 Oh well i have managed to solve my original problem by using Xilisoft Video Converter as it uses its own codecs etc i have no probs now
AVI to MPG with Mainconcept
By electrontau in forum Video ConversionReplies: 5Last Post: 1st Aug 2008, 14:34 -
MainConcept products !? use it or not..
By Harviz in forum EditingReplies: 1Last Post: 1st Dec 2007, 20:14 -
Problems Converting AVI to SVCD
By wiseguy109 in forum Video ConversionReplies: 3Last Post: 6th Oct 2007, 14:17 -
Avi to DVD (mpeg2) in Mainconcept Mpeg Encoder, basic how to
By reboot in forum User guidesReplies: 31Last Post: 6th Aug 2007, 15:56 -
Mainconcept DV Codec Vs. The Rest
By SeeNoEVO in forum Video ConversionReplies: 25Last Post: 5th Jun 2007, 08:16
