is it possible to take the audio of a video concert that i have saved on my pc and put it onto cd so i can play it through my hi-fi? if so how can i do this??? i use nero 6. cheers for all help.
Results 1 to 10 of 10
Hello,
Yep baldricks link will give you plenty of suggestions.
You can also rip the ac3 file in streamproccessing mode with dvd decrypter. Then you can use besweet gui to convert the ac3 to wav or mp3.
Then just burn a mp3 disc or make a audio cd from the wav/mp3 files.
I HAVE BEEN TO TWO SITES AND TRIED TWO PROGRAMMES - DVD Audio Extractor AND DVD AUDIO RIPPER. BOTH OF THESE PROGRAMMES CANNOT SEE THE AUDIO FILE ON MY HARD DISK WHICH I WANT TO TAKE THE AUDIO FROM? IN THE PROPERTIES FOR VIDEO FILE IT SAYS THAT THE AUDIO FORMAT IS MPEG LAYER-3. IS THERE A WAY ROUND THIS? DO I NEED THE FILE ON DISK TO COPY THE AUDIO???
Can you open that file with something like Windows Mediaplayer?
MP3 is the abbreviation for MPeG1 Audio Layer 3.
www.nomadworld.com/support/faq/welcome.asp?subtype=&faqtype=1&cat=3006&id=3034&page=1 -
If it is video with mp3 use goldwave, virtualdub and save it as wav.
Tools and guides:
https://www.videohelp.com/tools?toolsearch=&s=&orderby=Name&hits=50&convert=AVI+to+WAV&...+or+List+tools
And video with mp3 is not dvd audio.
Seeking help - convert/burn .OGG(audio only) 5.1 to DVD-Audio 5.1
By cinesimon in forum AudioReplies: 0Last Post: 18th Oct 2010, 18:28 -
How do I rip a DVD to a multi-Audio or a DUAL-Audio AVI?
By KneeRow in forum DVD RippingReplies: 8Last Post: 23rd Jan 2010, 13:40 -
No Audio On AVCHD-DVD, How To Remove Other Audio Tracks From MKV File First
By elistian in forum Video ConversionReplies: 1Last Post: 14th Dec 2009, 06:03 -
Easy DVD to MP4/MKV with Dual Audio, 'soft' Subtitles, and 5.1 Audio?
By Grovest in forum DVD RippingReplies: 4Last Post: 3rd Nov 2008, 04:12 -
Ripping Audio with ImTOO DVD Ripper Platinum 4 vs DVD Audio Extractor
By xtreme469 in forum AudioReplies: 0Last Post: 29th Sep 2007, 03:06
